Yesto hook up the sub, i need to cut those terminal ends off the white/black/red/brown wires and then strip just enough to hook into the quick connect plug, right?
Check here: https://wranglertjforum.com/threads/replacing-factory-dvc-sub-with-svc-sub.65062/how do i pair them up? red and black are one positive/negative pair on one side, and brown/grey as the other positive/negative pair on the other side?
I ran across this video looking for something else. Though it might be helpful since you asked about an 8".Do you know if an 8" ring that would allow a Kicker 8" RT to fit in the stock center console?
Seems like this guy had good luck getting one in the console with minimal fab work.
