Question for you all. I recently acquired a TJ from my cousin. He sold me an 06 TJ wrangler X 4.0L automatic. His front drive shaft was bent from frozen or failed U joints, the shop took it off and threw it out. He purchased a new 42" driveshaft and sent it with the jeep when i received it. I went to throw it in the other day and it appears to be about an inch off? Am i missing something here? I purchased some hardware from dead jeep parts, the front has the shorter bolts and the shackles, the rear has the longer bolts that go in from behind, but no shackles. All the mounts are present on the front diff, and on the transfer case, but alas, too short. The driveshaft i have is a one piece, but looks like it was two separate pieces that were welded together. I'll post the pic here below of the one i have. I've really only dealt with driveshafts that have slip yolks, so this one is confusing me.
Any thoughts would be appreciated.
