Hey everyone!
New guy here but, long time creeper.
I just picked up my first TJ, its a 2001 4.0 auto Sahara w/219,000 miles. It ran great when I bought it and I was able to get about 80 trouble free miles out of it before the fun started.
The Jeep threw 3 codes about a week ago. P0300 (multiple cylinder misfire) P0302 (cylinder #2 misfire) P0305 (cylinder #5 misfire).
If you start the Jeep cold with the codes cleared it starts and runs great, once you start driving you get about 5-7 minutes before it throws the cylinder #5 code and you can feel the studer when that happen. Within just a few minutes of that code, it throws the cylinder #2 code with the flashing CEL light and feels like it is in a limp mode.
I am not an electrical guru of any sorts but, my buddies put a meter on the injector plugs and it looks like I loose the pulsing ground on 2 & 5 once it warms up.
Things that I have replaced
-Spark plugs (Champion coppers gapped to .35)
-Coil pack
-Crank position sensor
-Cam position sensor
-Both upstream C02 sensors
Just some other variants to add to the mix. The guy I bought it off of did do a cut and splice on the fuse box under the hood, everything looks tight and right under there. The oil pressure gauge doesn't seem to work correctly so someone put a manual one inside the cab, it has roughly 55LBS at start up and gets down to roughly 25ish once warm.
The coolant temp gauge holds pretty steady right in between the first dot and 210 once "warm".
-Coil pack
