I ended up getting the Kicker Comp RT 6.75 DVC 2-ohm for cheap, so I am looking for an amp now that will fit under the driver side dash to power it. I also have 4 Infinity Reference REF507F powered by an Alpine UTE-73BT headunit. Most post I have found reference the DVC 1-ohm version version which makes a difference since I can only wire mine to 1-ohm or 4-ohm. Should I look at a single amp to power the 4 REF507F's and the Kicker? I am not trying to spend a lot and I don't think name brand matters much if I can find a review where it was tested and can power the Kicker at around 150 watts RMS. And, it fits under the dash.
Some I found for just the Kicker:
PLINIUS PHF450D
Skar Audio RP-350.1D
NVX VADM1
Soundstream Stealth Single Shot ST1.500D
PLINIUS PHF450D
NVX VADM1
