ronsuriano
Maybe even better. In later-year TJs, my understanding is you need to trim some sheet metal to make room for the adapter.
Something to look into - Dash pods. They give you the mounting points for the 5.25" upgrade, plus a space to add the rear baffling padding.
Dash Pods
Sony makes a DSX-M80 that is 45 watts RMS per channel and marine grade, so slightly water proof.
I've found it to be acceptable.
(If you still have factory speakers on a TJ, upgrading those would make a noticeable difference.)
How did you wire the power?
Screw in plastic pods, no modification needed for '03-'06.
https://www.crutchfield.com/p_663DSHPD03/Select-Increments-Dash-Pods.html
Or these. Helps if one refreshes the thread before posting...![]()
These do help the sound a lot as they offer a full enclosure for the speakers as opposed to the open back design from the factory. With these I did have a pretty big drop at 180 Hz, so I ended up going with pods mounted on top of my dash.
If you aren't as picky as me you'll probably really benefit from these.
It helps if you reinforce these with CLD or even a fiberglass mix.
Just the yellow.
The crutchfield pods have worked great for me. No more need to front fade a bunch just to hear the front speakers.
I would love to try a DSP to see how good the speakers can sound, but I can't justify going that route for an open air rig.
The whole open air design from the factory is wonky, you get so much cancellation. Having those enclosed pods makes such a difference.
Hard to say how much benefit you'd have topless. I run a hard top year-round since my Jeep is my daily. It was a substantial upgrade to audio quality, and you can get a Dayton for under $200.
Yes I had that experience changing my original soundar out when I had a the hardtop, i run softtop year round now so should be able to get this done next weekend.
Im all done for hardware now as the replacement tweeter showed up,
im using the crossover that came with the blam lives
just be using some tessa tape and acoustic padding inside the bar and the parts that will make contact with the sportsbar.
Also had this spacer made for the sub woofer to avoid it making any contact.
A lot of advice here recommending adding closed back pods for your dash speakers. This is wrong. I think many are confusing directing the sound so it emanates as much as possible through to the cabin, for this use speaker ring or simple foam.
All these car speakers are ‘infinate baffle’ speakers, meaning they are designed as open air speakers. If you must used those closed pods the just cut the back out. This will mean they will work as designed.
