Iv been trying to figure out a p0153 code for a while now. 2005 jeep LJ. Using a tester light I connected the alligator clip to my positive battery terminal and then probed the positive battery cable and the light turns on ever so slightly and then dims down and off completely within 2-3 seconds. When I touch the probe to the negative battery terminal it turns on strong and bright.
I’m wondering if this indicates I have no shorts at all in my wiring harness? Because from what I read and watched in tutorials, if you clip the positive terminal and touch the positive cable the tester light will illuminate indicating a short somewhere and then you proceed with removing fuses and unplugging the pcm, ground points, o2 sensors etc etc until that tester light turns off.
Any help is appreciated. Im confused why my tester light isn’t turning on after touching both positive leads and if it means I have no short circuits or im doing something wrong with this diagnosis trick
