With also moving back east I have annual inspection and emissions. One of the biggest things I’ve had issues with is my exhaust. With the new motor I put on a brand new, not cracked header. That was one thing solved but the rest of the exhaust was a shit show to put it simply. Every joint leaked and would move cause more or less drone in the cab. The tailpipe was ripped off wheeing so I welded on an axle dump (which won’t pass inspection even if the system didn’t leak). Plus the muffler was smashed in.
Because of the tummy tuck my exhaust has also not fit like oem as the muffler would hit the tub where the back seat passenger side foot well it. This made a noise and was so close it would heat up the tub so much on long drive like the cross country one I took, it would melt the carpet above it.
So rather than just getting a bolt on kit and having to mess with it not fitting with the tuck I just took it to a local exhaust shop that had the best rating around.
Got a full stainless set up from the manifold to the back of the tub. Magnaflow ss cat and magnaflow 409ss as I wanted a bit of noise but nothing that would be be obnoxious and make people think I’m a ricer. Fits like a glove and has no movement and is far away from hitting anything like the Oem set up did.
Overall I’m super happy to have a jeep that doesn’t sound like a tractor and fits perfectly to the tuck. The only thing I worry about is that tail pipe being so far out. I will see how far back I can trim it while still being legal even if I need a tip that is angled down some without actually hanging down.
Just out of curiosity about how much did it cost for the SS exhaust?
Since I've built all my exhaust systems out of SS I'm curious.
