DN EG 3
What year, make, model (trim level) and transmission are in your TJ? That will pretty much confirm or deny whether it is indeed 3.55 gears (which it likely is).
I also updated the chart in the first post, you should have a 28 tooth gear, assuming you do indeed have 3.55 gearing.
It's a 97 Sahara with an automatic transmission. I'm the third owner, according to the guy I bought it from. I believe it's been modified due to not getting the correct parts, to replace my rear drive shaft u-joints, when I told the parts guy that it is a 1997 Jeep Wrangler Sahara 6 cylinder.
