High idle while pressing in clutch
Jodh
Dallas
After driving and coming to a stop and pressing the clutch my jeep will sometimes idle at about 2200 rpms. If I rev the engine it will settle back down to normal idle speed about 750. No CEL or codes. I've tried using propane around all the vacuum lines and fittings and not finding any leaks. Any ideas what else to try? 06 4.0 6spd
Reactions: Leinhit
I pulled the IAC off and cleaned it. It wasnt that dirty since I cleaned it about a year ago along with the throttle body. It did it once on my way to work today. I'll try that DIY smoke machine. Let you know what I find. The problem is it's so intermittent when it does it. Sometimes when I stop sometimes just driving and shifting gears. Most of the time its normal.
Don't remember what or if I didnt anything. It hasn't done it anymore.
