Day 70. LJ3a is back on all fours after Hp60/shave14b conversion with Clayton 3link/triangulated 4 link and ORIs.
Not done but it’s close. So close. Just Hydro lines and fluid. Muffler, brake lines and bleed. Charge the ORIs, Locktite &torque check everything.
2nd weekend gone and still not done a cooling system flush....had to work this weekend and last weekend was taken up with working on my daughters car...
However, as a way of saying thanks she bought me an old number plate from a flea market...another one to add to my collection.
This is just a small part of my collection
Welp I got the axle primed&painted
The color looks alot brighter on picture,looks more metal like and darker
pressed out the old bearings to use as setup bearings,die grinded ALL of the bearings to where its just a tight slip on fit to the pinion,carrier etc!.....It took me a while but im all setup for tomorrow to begin the regearing process😁......Just needa get new hardware for the axle shafts ! Reinforce the Lca brackets by welding some plate to test how weldable this paint is 🧐
Only the pinion bearing gave me hell when trying to press it out but that's it
Being recently purchased and myself being a Jeep newbie, I sought out a trustworthy mechanic here in town to give it a good work over. The shop came with very high recommendations from a close and trusted friend.
I had the following done to it:
  • rear main seal replaced (was leaking like a sieve)
  • motor mounts replaced
  • throttle body serviced and cleaned
  • all wiring checked, some replaced where insulation had dryrotted.
Parts and labor came to right at $475usd. With this and the new tires, I feel ready to hit the trails up in the big mountains!
Wait, what? You paid $475 and it included replacing the RMS?
AC was feeling weak so added some freon, watched the gauges & took the whole 12 oz can. Showed 35 low side, 235 high side at about 80°. Went for a drive & she was blowing 36° from center vents. Hitting 111° today, just in time!!
Reactions: Kiwi TJ and Zorba
Pinion could go in some more it looks like
Opinions ? The gears are a but shiny since they are REM polished 😁
@hosejockey61
I'm at 7.5 almost 8 thou. For backlash which is in spec for this eaton trutrac IIRC
I agree pinion could be a fair bit deeper. Might want to start a separate thread though, so your posts don't get spread out and lost in this one.
Reactions: D's Jeep Wrld
@hosejockey61
I can barely see that get some light on it and give us patterns from both sides
And yeah, start a different thread.
Edit: your using too much marking compound. Use just enough to turn it yellow without all the buildup at the root.
Thank you man! That reassurance is what I needed
I really needa start posting on my build thread....my whole build is on this here thread 😅
Reactions: FarFire70
3 years of ownership and this is the only time I've seen this thing at e with the light on 😆
Drained all 14 ish gallons I had left so the tank won't weigh much when I drop it 😁
-Edit, I'm dropping the tank since im gonna sand down the fuel flow back valve,every now&then when I fuel up I get splashback!
