Did @NashvilleTJ put you up to saying this? You forgot the "only yellow LJs" part.![]()
Curious, have you ever had an LJ?
So this is a pic of the LJ I was looking at - great example of rusting from the inside out! Gonna pass on this one - the entire frame is probably like that!
Something is not adding up here. If I had not seen the pic of the rust hole by the body mount, I'd say the LJ looks to be in very good shape.
Looking closer at the offending pic, it looks more like some kind of damage to me - almost like someone blasted though it with a welder doing something and then never fixed it. Something is strange about the spot - especially how good the rest of the rig looks to me.
Except this pic.
So just looking for an opinion on that white jeep and if anyone sees issues with the rust. 116,000 miles and about $8000
Thanks, so sorry i have not done that - any recommendation on the camera to use for that? Some type of scope or something - thanks so much. I am learning!
Maybe something like this:
https://www.amazon.com/Endoscope-Wa...-Inspection/dp/B0CG46T9ZF/?tag=wranglerorg-20
