Dyno Testing Bolt-ons On The 4.0
Haven't heard about that. Can you expand on that, please?
You can read about people having cracked/broken skirts in stock engines here and other forums. It seems to be more common in these 4.0s than any other stock engine that I've messed with. I haven't had the issue, so I’ve never had to go down that rabbit hole figuring out why. From what I've been told and read, skirts tend to break because of bad/wrong material and/or excessive tolerances (rocking).
Looks as though the speed is limited in this PCM at 112mph or MACH 0.15
This '97 has a replacement Wranglerfix PCM in it from a few years back before I owned it, so that limiter may be different than stock.
You must have a feather foot. 😁
Damn no respect....
I was known to rev my 4 angry squirrels up to the redline more than once... But I did say most members... But then I guess the members who are watching this thread aren't "most" members... I'm just going off the number of people who say they never rev their 4.0 above 3K RPM's and wonder why it's so slow.
Damn no respect....
The stall convertor in my LJ is 3500, so it's usually above 3k.
Reactions: Apparition
But you don't have a stock transmission correct? What is the stall on a 42RLE or 32RH?
My point was that I was trying to make is getting the HP & TQ numbers where most of our Jeeps operate at as opposed to the normal dyno runs that are mainly showing peak HP & TQ. Most of us drive between 2k & 4K RPM's on the street I'd think. But then I could be wrong too...
No, I have the 6R80 and the first gear is super low, that's why I went so high on the stall. Realistically because of the low gears and the lighter weight of the Jeep vs the Navigator it came out of the stall starts to flash around 2500 making it only slightly looser than stock. The 32rh in this '97 flashes at 1800-2000 rpm according to my tests.
While I'm sure it'll be said again I want to thank you for doing this... Doesn't matter that I don't have an dog in this hunt...
One of us needs to bring a Hemi powered Jeep to ya...
Definitely would be cool to see a V8 on Jezza's dyno...
:unsure:
...and it would have to be a Hemi. An LS would never turn that big drum.
:unsure:
Well I want/need to dyno mine some day..... When I start traveling TX is on my route...
That went without needed to be said... Don't want to shame anyone ya know.
