Hey TJers,
Installing a resonator did wonders for further reducing how loud my BEW TDI swapped TJ Wrangler is when driving down the road. However, getting the resonator to fit and have all my exhaust components line up was a challenge that took longer than expected. One last note, I had to reset my phone, so I lost some pictures, so I had to grab screenshots from my videos.
Until very recently, one of my biggest dislikes about my TDI swap on my Wrangler has been how loud my swap was when going down the road. It's not that I don't like hearing my engine and the turbo making noises, but when it's so loud that you don't want to drive it for long periods of time, that's an issue.
One thing going against me for the noise issue was my muffler, it's a straight through design, and going to a chambered or one that is a three-pass would make the exhaust quieter at the cost of exhaust flow. I've known about resonators for years, but I've never had the need to install one either. So I went and got a cheap generic one online so I could see if it would make any difference. Part of the reason for getting a cheap one was that, at some point in the future, I'm upgrading my exhaust from 2.25" to 2.5. Because of that, I consider my current setup a proof of concept.
The resonator wasn't too difficult to install, though I did have to modify my down pipe to make basically an offset pipe so I would have the room to clear my frame rail for all the components to fit properly. To make the offset exhaust pipe, I took a 45° bend exhaust pipe, cut it in half, rotated one piece 180°, and then welded the exhaust pipe back together.
To be 100% honest, when I removed the downpipe to make the offset section, I did discover that 2 out of the 3 nuts holding the exhaust flange onto my turbo were loose, which I'm guessing is where some of the exhaust noise was coming from. Once everything was assembled, I took my Wrangler on a test drive and was blown away by how much better everything sounded. What I can't tell you is how much of a difference the resonator makes from just tightening up the downpipe to the turbo. All I care about is that I can drive my swap without the exhaust noise droning, and I no longer need hearing protection.
