I’d have to go smell it again to see. Worked on my jeep today and everything was thoroughly coated in PSC steering swepco so I didn’t need any.
Huh. That’s weird
I usually kroil the hanger just to make it that much easier. Not sure if that’s common or not.
I used PB Blaster, Kroil is to expensive.......
Jerry says PB blaster is garbage
Maybe The Ghost of Jerry will post that chart we've seen a gazzilion times...
Got the exhaust installed in the JKU, of course it was an excuse to buy another tool!!!!
Exhaust hanger tool.
What does an exhaust hanger tool do? I’ve never seen or heard of one.
You use it to push the metal peice out of the rubber hanger bushing.
New tool day in your future is see...![]()
You need to scratch off the "10" from those and put a different number on them. That way, you'll fool the 10mm Gremlins that are out to steal all 10mm sockets, even universal joint versions...I did get these two shallow 10mm universals for an upcoming job on my wife’s car.
You need to scratch off the "10" from those and put a different number on them. That way, you'll fool the 10mm Gremlins that are out to steal all 10mm sockets, even universal joint versions...![]()
