AC didn't work when I bought the vehicle a few months ago. My mechanic installed an AC system repair kit that included a new drier and gaskets, etc... changing this stuff out means that there is no refrigerant in the system right now.
I brought it to a guy I know who does AC charging and he put gages on the system and tested for leaks and there were no leaks. He told me to start it up and turn the AC on, and when I did he said the compressor is not engaging. He checked a bunch of electrical stuff, got underneath and did something with the compressor and then told me that the compressor was bad and needed replacing.
I got home and looked online and I see where there could be several other things that could be the problem other than the compressor being bad. Relays, switches, and wiring. Also, I read a post where it was said that as you fill the system with refrigerant, the low pressure switch is activated and the compressor will start up.
I don't want to just replace the compressor without checking a few things and without a little feedback from you'all.
Thanks,
Greg
Thanks,
Greg
