My new-to-me ‘99 A/T 4.0 w/AC has obviously been lifted but I’m not sure just what I have. It sits level but is obviously higher than stock. The frame to body bushings look to be stock.
I looked for part numbers on the springs but couldn’t find any brand markings on them. The rear springs do have “216” on them and the front springs have “214” on them. The new-looking Bilstein shock part numbers show the rears are for a 3” lift and the fronts are for a 0 to 2” lift. There’s also a slip yoke eliminator installed, making me believe that the rear lift is indeed at least 3”. That or someone spent their money in anticipation of installing a 3+ or higher lift in the future.
My Jeep familiarity is only with JKs. I know those in stock condition were always raked down in the front. I am trying to get familiar with the TJ. I’d think if it was raked down in front to start with the 0 to 2” lift in front with a 3” lift in the rear wouldn’t have it sitting level. The sway bars seem pretty level so I’m guessing that whoever installed the springs also swapped the sway bar links. But only guessing. Other than the springs and shocks everything else looks to be original.
Do the 214 and 216 numbers on the springs mean anything to anyone here? Is it common to raise the rear more than the front and end up level?? I’m not even sure that the shocks match the lift amounts at this point.
As usual, thank you in advance for any help.
