If you weren't following the JKS Rear trackbar questions thread, it got somewhat hijacked by another topic that deserves it's own thread.
JKS is no longer providing their rear track bar with a Johnny Joint. Not sure what other components they used to provide a JJ for that they've stopped.
Their new joint is something they refer to as a "COM Bearing". No idea what this means, but it looks a lot like a heim joint. So far I haven't found anyone to have taken it apart and examined it. Their website listing for the part describes a "Spherical urethane bushing" which seems to refer to the JJ but is outdated. Their replacement parts diagram also shows Johnny Joint parts but the links are dead.
However, their JK track bar has the following info regarding the COM bearing.
Photos of the joint in this post with the misalignment spacers in position, and in this one without them.
I had an email exchange with JKS support, where they could not provide any additional technical information on the joint and indicated that it would not be possible to retrofit a JJ into this housing, nor are the old JJ housings still available.
I responded asking for warranty period failure rates for both joints to compare but acknowledged that he probably wasn't allowed to provide it, if it even exists.
I think a number of us are interested in anyone's experience with this joint and it's reliability. I don't like the idea of the joint getting loose or starting to squeak in a year and a half after the warranty is over, but I just dropped over $3k rebuilding my axles, locking, and regearing and am now doing a SYE so my Jeep budget doesn't have room for the $200 premium on a Currie bar.
JKS said:While we have earned a stellar reputation over the years for building a top quality adjustable track bar for the 2007-2018 Jeep Wrangler JK there is a need for more less bushing deflection and more bind-free articulation in long travel suspension applications. With this need present in the market we are pleased to announce we are offering heavy duty versions of our adjustable track bar for the JK redesigned with a COM bearing at the axle mount for improve offroad performance....
At the axle mount the machined end on the HD Track Bar features a large heavy duty COM bearing for bind-free articulation capable of more misalignment for long travel suspensions. The COM bearing uses a self-lubricating, injection molded race rated for 42,000lbs of static load for long life and reliable performance. Along with the COM bearing a pair of high-angle misalignment spacers are supplied to maximize angular travel of the COM bear end allowing for vast improvements for offroad performance under your Jeep JK.
JKS Support said:
JKS Support said:We use a sealed com bearing that does not require a grease zerk now. We have found these to last just as long without the normal greasing needed to keep them quiet
JKS Support said:I do not have a brochure on this com bearing that we are using. We have been using this style for around 4 years now, and a few years before that with product testing and development. You are far from a “guinea pig” and we would never use customers as test mules
JKS Support said:I am also unsure of what website you are looking at, as our website and instructions are all showing the track bar in its current and correct state, with no grease zerk.
The JKS Warranty covers wearable items for up to 1 year from the date of purchase, as it always has, even when we were using the JJ.
The current end can not be converted, as it is machined differently for the current joint. Also, we do not have the previous joint/end available for purchase anymore.
Feel free to let me know if you have any other questions
