I have TPMS on two of my vehicles and it has saved me twice.
Any recommendations for aftermarket on an o6 TJ?
I use my eyeballs
If I wanted those, I would've bought a JK.
I have cheap Chinesium one I got from AMZ. I got it mainly to monitor TP when I flat tow it. I like having it to check TP while wheeling as I run 14-16# and worry about losing a bead.
My eyes must not be that good. I can't tell the difference between 16 and 33...
It's not that complicated. You can use a tire gauge without ever moving the vehicle.I am simply looking for a way to see if the tires are up to air without pulling in the garage and checking pressures.
Why would your tires ever be at 33?
33 is the recommended pressure for my tires.
Recommended by who? Spinal surgeons?
What is you deal? I have a stock 2006 TJ with STOCK WHEELS and tires The recommended tire pressure is 33 PSI. WTF!!!
Will that system get a good signal from the toad to the rv?
