As the title says, the blower motor in my 02 just quit working the other day. I could not get the fan to turn on on any speed with the dash switch. I have checked the speed switch on the dash and it is working as it should, has not melted. Pulled the fan motor out and applied 12V of power to it and it works just fine.
I did notice that the relay cover came off and there was some corrosion on it, so I replaced it and that did not fix the problem. I put the old relay back on and when I manually make the connection, the blower turns on and adjusts to the speed that is selected.
Looking at the wiring diagram, it looks like the power for the relay goes through the blend air door motor. Should I replace that too?
What else could it be or have I missed something along the way?
