@mrblaine, quick question for you regarding the Savvy cable shifter kits. Is there a difference between the NP231 and NP241 for the body side bracket? I cannot for the life of me get the cable to align with the body-side shifter. (The cable points more to the hinge point of the shifter rather than the end where it should mount.) There's even a bend in the bracket where the cable goes through that seems to make it worse. The T-case side bracket lines up perfectly.
I've tried the loosen everything up and see if things will move into place method to no avail. I'm curious is there are two brackets, and if so, maybe I got the wrong one?
