OK, this is fascinating. Doing a little research on this, Google's AI gave me this information on charging voltages for AGM batteries at a given temperature:
________________________________________________________________________________________________________________________________________
Automotive AGMs are charged by the powertrain control module (PCM), which varies the voltage based on the battery's temperature
. This process, known as temperature compensation, prevents overcharging in warm conditions and undercharging in cold conditions, both of which can shorten battery lifespan.
How temperature compensation works
Lead-acid batteries, including AGMs, have a negative temperature coefficient. This means that for a given charging voltage:
- In cold temperatures, the internal resistance increases, so the voltage must be increased to ensure a full charge.
- In hot temperatures, the internal resistance decreases, so the voltage must be lowered to prevent overcharging.
The reference point for adjustment is typically 25°C (77°F). The standard compensation rate for a 12-volt battery is a reduction of -24 mV/°C (
-0.024 V/∘Cnegative 0.024 V / raised to the composed with power C
−0.024 V/∘C
) or about -13.3 mV/°F (
-0.0133 V/∘Fnegative 0.0133 V / raised to the composed with power F
−0.0133 V/∘F
PCM charging chart for a 12V AGM battery
The PCM uses temperature compensation to adjust the charging voltage throughout the multi-stage charging process, particularly during the absorption and float stages. The following chart provides approximate target voltages based on a typical 12V AGM absorption voltage of 14.4V at 25°C (77°F).
| Temperature | Voltage adjustment for 12V system | Target absorption voltage |
| -20°C (-4°F) | +1.08V | 15.48V |
| -10°C (14°F) | +0.72V | 15.12V |
| 0°C (32°F) | +0.48V | 14.88V |
| 10°C (50°F) | +0.36V | 14.76V |
| 20°C (68°F) | +0.12V | 14.52V |
| 25°C (77°F) | 0.0V | 14.4V |
| 30°C (86°F) | -0.12V | 14.28V |
| 40°C (104°F) | -0.36V | 14.04V |
| 50°C (122°F) | -0.60V | 13.80V |
According to this info, for these PCM charging levels 77 degrees F is the reference point - meaning the point at which the target voltage is raised or lowered according to temperature. The values indicated are certainly more aggressive than the standard values in the PCM table on my Hemi.
From this information, I developed the following estimated voltage levels by temperature in the PCM table. The voltage for 32 degrees and 86 degrees come directly from the AI chart. The other 3 voltage levels I interpolated to get the charted line for the proposed voltages flat. The result is approximately a .5 volt increase at every temperature.
I have no idea yet if the PCM will accept these exact proposed voltages, but I may give it a try.
Does this sound reasonable? My question would be: Is the "Absorbtion Voltage" referenced in the AI information the proper target?
