So I had been collecting info on the different speaker enclosure, pod and adapter options for the TJ I have come across over the years and thought it might be helpful to share here for those looking at audio upgrades. Below is 40 of the various known options (both current and past) with links and a photo of each.
Would be curious to hear from those who have experience with any of these solutions or if there are any other ones I missed (besides custom built enclosures) let me know.
DASH SPEAKERS:
Select Increments Dash-Pods - Closed for 5.25" 2-Way Speakers
3D Printed 5.25" Front Speaker Pod - Closed for 5.25" 2-Way Speakers
3D Printed 6.5" Front Speaker Pod - Closed for 6.5" 2-Way Speakers
3D Printed 4'x6" Front Speaker Pod - Closed for 4'x6" 2-Way Speakers
Electroplated Front Speaker Adapter - Open for 5.25" 2-Way Speakers
3D Printed 5.25" Front Speaker Adapter (Also on Thingiverse) - Open for 5.25" 2-Way Speakers
3D Printed Front Speaker Adapters - Multiple open versions of adapter plates for various speaker sizes
3D Printed Component Speaker Adapter (Link to buy on ETSY directly instead of printing) - Closed or Open for 4" Components (tweeter angled toward occupants)
KICK PANEL SPEAKERS:
Select Increments Mod-Pods - Closed for 5.25" 2-Way Speakers
Q-Logic Q-Forms Kick Panel Enclosures - Open for 6.5" or 5.25" Components (cut driver hole yourself so can install smaller driver if necessary)
SSV Works Front Speaker Pods - Closed for 6.5" 2-Way Speakers (Discontinued so somewhat rare)
OVERHEAD SPEAKERS:
3D Printed Adapter ring to Change OEM Sound Bar to 6.5" Speakers (Link to buy on ETSY directly instead of printing) - Closed for 6.5" 2-Way Speakers (note that many 6.5" speakers may not require an adapter ring at all but this requires no modification to the OEM sound bar)
3D Printed Spacer Ring to Change OEM Sound Bar to 6.5" Speakers - Closed for 6.5" 2-Way Speakers (note all this does is take up the gap in the OEM 5.25" speaker recessed area to make mounting a 6.5" speaker easier)
Vertically Driven Products 6 Speaker Overhead Soundbar (alternate 2-way version) - Closed for 6" Components Plus Two 2" Mid Range Speakers. Also available in a dual 6" 2-way speaker version (similar to OEM)
Vertically Driven Products Overhead Sound Pods (alternate 2-way version) - Closed in Both 6.5" 2-Way Variant or 6" Components Variants
DS18 Overhead Bar System - Closed for Four 6.5" 2-Way and Two 4" Speakers
TJ American SoundBar - Closed for Four 8" Drivers and up to Four Tweeters
3d Printed Overhead Pods - Closed for 6.5" 2-Way Speakers (Model could be modified for other speaker sizes before printing)
Select Increments Sky-Pod - Closed for 4" 2-Way Speakers
TAG Overhead Sound Vault - Open for One 6.5" Speaker two 2.5" Speakers and Two Tweeters (Includes lockable storage but discontinued and rare)
Bestop Overhead Console - Two Tweeters at front of Console (Discontinued and very rare, may have only been made with their glass top kit limited info available)
Custom Overhead Enclosure - Unknown cu. ft. for any speaker configuration (can be customized to your liking)
REAR SPEAKERS:
Vertically Driven Products Sound Wedge (alternate 2-way version) - Closed in Both 6.5" 2-Way Variant or 6" Components Variant (Rugged Ridge offers the same product HERE)
Select Increments Opti-Pods - Closed for 6.5" or 6.75" 2-Way Speakers (includes rear cup holders)
Tuffy Lockbox Speaker & Storage Set - Open for "4 to 5 inch speaker" (includes lockable storage)
Select Increments Quad-Pod - Sealed .50 cu. ft. for 6.5" 2-Way & 8" Subwoofer (comes in set of 2 discontinued so somewhat rare)
SUBWOOFER(S):
Select Increments Stealth-Pod - Sealed 0.70 cu. ft. for 10" Rear Firing Subwoofer (can easily be removed)
Select Increments Sono-Pod - Sealed 0.73 cu. ft. for 10" Down Firing Subwoofer (can easily be removed)
Q-Logic Q Customs Subwoofer Enclosure - Sealed 0.65 cu. ft. for 10" Rear Firing Subwoofer (can easily be removed)
MTX Thunder from Sub Box - Sealed 1.48 cu. ft. for Dual 10" Down Firing Subwoofers (can easily be removed)
DS18 Tailgate Loudspeaker Enclosure (alternate version with only two 10" subwoofers) - Sealed 0.85 cu. ft. for Two 10" Forward Firing Subwoofers and Two 3" speakers/tweeters
SSV Works 10" Center Console Subwoofer Enclosure - Sealed unknown cu. ft. for 10" Side Firing Subwoofer (Only compatible with the 2001+ 2-piece center consoles, discontinued so somewhat rare)
Mopar Sound Deck - Sealed unknown cu. ft. for 8" Front Firing Subwoofer and Two Tweeters (easily removable and doubles as lockable storage but somewhat rare)
Custom Enclosure in Rear Bench Seat - Sealed or ported ~0.87 cu. ft. for, Single 8"/10"/12" or Dual 8" Down Firing Subwoofers (can be customized to your liking)
Custom Under Rear Seat - Sealed or ported Unknown cu. ft. for, Single 8"/10"/12" or Dual 8" Up Firing Subwoofers (can be customized to your liking)
Custom Ported 12" Enclosure behind Rear Bench Seat - Ported unknown cu. ft. for 12" Forward Firing Subwoofers (can be customized to your liking)
Custom Sealed 15" Enclosure behind Rear Bench Seat - Sealed unknown cu. ft. for 15" Forward Firing Subwoofers (can be customized to your liking)
Custom Ported Dual 12" Enclosure for Rear of Vehicle - Ported unknown cu. ft. for Dual 12" Down Firing Subwoofers (Unclear whether this will fit behind rears seat or is designed to replace it can be customized to your liking)
OTHER PODS:
Valicar Alu-Pods - Closed for Tweeters (Can be mounted in multiple locations)
Select Increments Versa Pods - Closed for 4" 2-Way Speakers and can be mounted in multiple different locations (A-pillar, Roll Bar, Rear Fender Well, Under Rear Seat, etc.)
DASH SPEAKERS:
OVERHEAD SPEAKERS:
REAR SPEAKERS:
SUBWOOFER(S):
OTHER PODS:
