OK, I went way down the rabbit hole designing a ported dash enclosure. And I did some math along the way for the s's & g's.
Here's the pod with an integrated elliptical bass tube:
It's all the same material/color... I just highlighted the tube in a different color for visibility.
The area of the tube is 264.6 sq mm, so the effective diameter is 18.3 mm. The pod volume without the tube and speaker is 3,483.86 cc, so, figure around 2,800 cc loaded with the tube. I used this website to calculate desired port length for tuning frequency.
The coax speakers I'm looking at have a bottom response frequency of 55 Hz. Here are the tube length calcs for a few tuning frequencies:
55 Hz - 3.2"
70 Hz - 1.8"
80 Hz - 1.2"
Bigger tube IDs require a longer run for the same frequency. I stuck with a small effective ID, but could potentially go a bit bigger.
55 Hz - 3.2"
70 Hz - 1.8"
80 Hz - 1.2"
