Trade offs, life is full of them
Says the guy who's got one of each...
Says the guy who's got one of each...![]()
The TJU has 4’ more turning radius. 5” more passenger room and 10” more cargo room. 1500# more towing. These statistics are why I went with an Unlimited. The extra room for gear, especially being able to put a full size cooler in with the back seat down, was the selling point for me. I tow a 1200# teardrop trailer and with an additional 300# of gear in the back and mine handles great going up and down the steep grades here in the West.
Which model you choose is based on your personal needs. For me the Unlimited was the perfect choice.
Fully loaded for a 5 night trip to the Desert.
What gear ratio are you using? That is somewhat I am looking to do. Now I have 373's with 245/16 tires and it is okay with no trailer.
Let's talk about these measurements. What is the dimensions, on the floor, of the cargo area behind the rear seat?The TJU has 5” more passenger room and 10” more cargo room.
If I could move the back seat forward 5" to be in the same area as a TJ, I might be able to solve my need for a back seat and cargo space requirements with a LJ. In a LJ, I would need 32" minimum of floor space in the cargo area.
So this is measuring at the top of the tailgate to level on the seat back the farthest rearward of the rear seat? If that is the case, then moving the rear seats forward 5" won't get me the measurements I am looking for. If the LJ had the same room behind the seat with the seat moved forward as the TJ does with the seat out to the drop down in the cargo floor, an LJ would work for me.19” with the seat down.
39” with the seat up.
49” with the seat removed.
Measurements are taken at the height of the rear seat back and the front seats all the way back. Distances are greater at floor level.
I can fit 3 5gal water cans, my 2000W Honda generator, full size cooler, 5 bags of tools, 30’ rope bag, a bag with 30’ strap with soft and hard shackels along with my first aid kit. That’s with the rear seat up and the load at the height the folded up seat. Having stuff in bags makes packing everything in fit nicely. My clothing sits on the passenger seat in my expandable carry on and my travel cooler sits on the floor. I travel solo but I have more room in the back to pack higher if I bring a passenger. All my camping gear and dry food fit in the teardrop. Only things I can’t pack are my fire pit and firewood which sucks.
I do multiple 4-5 night trips a year and have packing fairly dialed in.
LJs indeed have a longer wheelbase but they also have a slightly worse departure angle.
Do you think it would be feasible to move the back seat forward 7"? It would be kids in the back and a PRP seat so it would be custom mounted. I'd also have a front harness bar too so not sure if that'd interfere with moving the seats forward. Granted I'm short and like the driver seat closer, but that's with my manual TJ. An automatic I'd probably scoot the seat back a notch.24” top of tailgate to back of seat. You lose some in the right corner with the door strap.
The cooler is 32”x22”x18” and has 3.5” to spare.
Good info. I appreciate you looking.I’ve only sat in the back seat once and the biggest issue to me 6’ 220# was the foot room. Recently went on a challenging run with a guy slightly bigger than me. I asked him how it was and he said OK. The LJ has 5” more room than a TJ.when folded up the rear seat is right ip to the fronts back so I don’t know where the 5” goes. Secure mounts for the seat and belts would be my only concern. I’ll take a better look tomorrow when it’s light.
Whatever gear ratio @bucky has, he has different tires and a different transmission than you. Apples to kumquats.
What's the rest of your tire size? "245/16" only tells half of the story.
245/75/16
So call them31"29.67".
To get greater accuracy with GrimmJeeper you need to subtract 1" from the listed tire diameter or preferably measure from the center of the hub to the ground and double it to account for squish. Using the easiest method subtracting 1":
4.88 2669 RPM @ 70 MPH
5.13 2806 RPM @ 70 MPH (lowest gears for Dana 30)
5.38 2943 RPM @ 70 MPH
LJ is better pulling boat or small camper, more stable.
