Hello all. Appreciate in help and or insight into my gear setup.
Here is the info:
Here are my questions.
Here is the info:
- 2006 Jeep TJ Unlimited Rubicon
- Has 110,000 miles
- Previous owner had the axles regeared to 4.88's
- Pinion bearing burnt up.
- Decided to upgrade to 35 spline chromoly axle shafts which required a new carrier, so went with a 35 spline ARB locker
- Nitro 4.88 gears.
- Curious about your thoughts on my current pattern. Backlash is currently @ 11,000", so need to tighten that up a bit.
- How are you guys running your airline for the arb in these Rubicon axles? I have searched extensively, and I swore I saw people recommending the rear plunger port for the original locker. At first I had thought this was the way to go, but after having played with it a bit, it seems like it may be to far back to make the connections. There is another option witch would be to run it to the more forward facing original air line location. Thoughts on this?
