@Fluxor any plans for stretch corners?
I have sold a few sets of blanks. I think its best to cut the wheel opening exactly where and the size you need after its bent. The wheel opening also gets into the bend radius and if you bend the corner with the wheel opening cut the material "flares" out towards the bottom. When you cut the wheel opening after bending you can trim it perfect and even get a little into the lower edge of the corner radius without things looking wonky. If you special order them I can also eliminate or move the fuel filler opening. Just not a one size fits all.
