I'm actually considering getting a set of these bump stops. I've seen a recommendation in this thread to anti seize the threads on the bolts but Rock Jock says to red Loctite them. Who is correct? Is the anti seize only if you're using a nutsert?
Here's the installation manual. https://www.rockjock4x4.com/Documents/TJLJ/CE-9122R.pdf
I read the installation guide. I’m going to use anti-seize.
The one thing I don’t like about these is the upper bumpstop uses an allen head bolt.
