I believe the correct way to fit bump stop extensions in the front is to drill and tap the lower spring perch and then bolt chosen means of extension to the perch.
As I have never tapped a hole before this is a bit daunting. How easy / hard is it to tap the spring perch? How hard is the material the spring perch is made of / does it require a particularly industrial tap to do it? What size bolt do people generally use? How big a hole do I drill before tapping?
Apologies for the very basic questions, any help much appreciated. I really want to avoid screwing this up.
