Google says the 392 makes 485 hp. Divide by 16 gets 30.3 hp/spark plug. Multiply by 6 yields 181.9 hp.
You're hemi produces the same hp per spark plug as an early TJ 4.0.
To instigate
But guess who has more sparkplugs huh
That isn't bad for the ole 5.9 honestly. I'd love to see what my '25 L5P would get deleted & tuned pulling my crawler hauler. It is GCWR of right at 26k. I'm getting 8-8.8 depending on terrain currently. I just can't justify D&T'ing it right now because of the warranty and issues the 10-speed is having. I'd hate to spend $5k to T&D and then have to drop another $5k for a new valve body because the stupid issues .My 04 ram 2500 5.9/6 speed got about 7.5 mpg over about 3200 miles, from Seattle to Knoxville TN. GCW 17500
View attachment 662964View attachment 662960
And I probably won't have it long enough to run out of warrantyYep. I definitely wouldn't delete if it's still under warranty
haha the pics are up in a thread I had about steering bits But I'll post again here I guess.. seeing what might need upgrading/replacing as I'm slowly building up the jeep I inherited. Got pointed to the lift info post which has been a good read.
I had to stand on my head to make sense of the geometry.
It took me a minute and even had to go back to see where he was from to realize it was a RHD.I had to stand on my head to make sense of the geometry.
Australian RHD model, handy for when the Roo is at the vets.
I was just messing with you. I saw you were down under. Welcome to the forum.
You might want to tighten this nut down and grease/replace the tie rod ends.
no particular torque or setting? just until it won't tighten any more?
So this the the TJ I recently bought.
Let's see....over the past week and a half I have done maintanence (plugs, coils, oil and filter), Big 7 battery cables, replaced the steering wheel, fixing the top with all the broken knuckles, removing crappy wiring, replaced blown front speakers, new front cats (AFE return...half price), Savvy transfer case cable, B&M shifter, Quadratec headlights, and more cleaning.
AND.........heater core just started leaking. Ordered Brassworks heater core. Still haven't installed the stereo and most of the dash is still apart from replacing the steering wheel....so I guess I have a head start. Sucks. I will prob have most of the dash pulled and take it to the shop and let them deal with installing becasue I can't pull down the A/C and I might as well have them flush the cooling system. Horray.....unexpeced fun!!!!
Another day of brake work. After doing these drums I was wishing I could do the drums on my Tacoma 5 times over again. In the end it wasn't that bad but glad I won't have to mess with them ever again hopefully. Painted the drums because why not. Put them on a little tight but I guess that's a self correcting problem.
Gonna bleed it tomorrow after I get another caliper to fix the leaking front one (RTV'd it to stop the leak) then test it all out. Still have some Hella headlights to install and I think I'll be done for a while.
On another note my engine fan seems to be running like the fan clutch is fully engaged now - failing fan clutch maybe?
