6-speed manual pops out of 1st
Should grab a spare while you are at it…
The assembly is $750
The boot is $2:15 and clamp another $1.18
So yes I will be buying spares. As much torque the diesel puts out I've cut the boots on the shifter plate. Ive cut it back already may need to trim some more.
I keep telling myself and my wife its cheaper to be buying parts now instead of later.
I should have bought a second unit for the Wife's JK and kept it on the shelf. I have to look back. But Im' thinking they were $525
  • Wow
Reactions: Apparition
Where did you find the replacement boot and clamp? At those prices, I need to get some spares, too!
The B&M may be extremely expensive. But you know what? It works, and it is considerably less expensive than rebuilding the 6-speed or putting in an AX-15. I actually consider it to be one of the best mods I have done to my TJ. I love the short throws.
Called them direct,
8664646553
I'll post up the engineers part numbers here in a few, save some time on the phone call
*Note got thrown away, I don't have those part numbers handy anymore.
You do have to spend a minimum of $10 for them to mail them though.
Reactions: sab
Called them direct,
8664646553
Thanks, I'll call them today. And, if you're going to get spares, don't forget to get spares of the gasket that goes between the B&M housing and the NSG370. I was able to buy a couple of those back in June 2023 the same way - by calling Holley. I posted about that experience here. For reference, that engineering part number is 4101381-88.
I just called and ordered the spares (all currently out of stock, unfortunately). For future reference, here are part numbers for spare parts for the B&M 45195 shifter for the NSG-370. Note that these are not regularly-available parts with a consumer part number. They have what Holley (owner of the B&M brand) calls "engineering part numbers," which are internal part numbers they use when they assemble the shifters:
  • Replacement gasket between shifter and transmission: 4101381-88
  • Replacement boot at top of shifter: 4101352-00
  • Replacement clamp for boot: 3401540-00
I ordered two of each of the above, and cost with shipping and tax (8.25% here) was a reasonable (to me, anyway) $42.82.
Reactions: NDSpeed
Finally ordering these parts
will also order two rubber boots and clamps
I got the boots and clamps I ordered within a couple weeks of my previous post, but the gaskets still haven't shipped - going on 3 months waiting.
  • Sad
good grief, i was cleaning the transmission tired of all the drips every time i drive this. skid plates are covered in oil.
pulled the shifter to make a gasket out of RTV and found both sides of the boot was cut. not just the side where the transmission contacted the cover plate when I installed the mustang shifter boot, I definitely needed to trim the passenger side metal plate down.
you can see right at the top of housing where it was making contact.
so the cut on the drivers side was from the factory i’m assuming.
