Did you threadlock the studs in the case?
Yes
You can see the red Loctite at the base of the threads. I applied liberally. It will definitely take heat to get them out should that ever need to happen (can't see why though).
You can see the one stud near the skid plate has no thread between the 10mm and 8mm threads. I have an aluminum bushing, or very thick washer for that one.
