Jwhite,
With the crown OPDA unit you won’t have to worry about the barrel of monkeys sound. It has a built in oil slinger that lubricants the top bearing. This will prevent cam lobe wearing (see Mopar service bulletin for details). That crown OPDA is a well built design; I have had it installed now for over 8 years. When I found out about the OEM OPDA service bulletin I took my 2005 TJ to the dealership and had the cam lobe inspected (- 8 years ago); their opinion was that the cam was not worn due to the OEM setup. I performed my own inspection and scoped the cam and came to the same conclusion. The OEM OPDA was not acting up or making barrel of monkey sounds; so I lucked out. I replace it with the recommended (thanks TJ forum) Crown OPDA and did the Cam / Ck sensor relearn. Nothing but happiness since.
Where you might see an issue without doing a relearn is at extreme ambient temperatures; if the phase sync is close to being out of spec the PCM will not throw any DTCs when driving; once summer temperatures hit combined with the dual min-cats ovens roasting the intake you could see some intermittent Ck & or Cmp sensor DTCs errors. Worst case is that the PCM will put the engine into limp mode preventing RPMs >2500. If that happens just take it to a trusted shop and have a relearn procedure. Do let anyone tell you that you have sensor issues or wiring problems or anything wrong with your TJ. Just have them do a relearn procedure and smile and wave at them as you drive out of the shop without DTCs.
Hope this helps; been there done this!
Happy Jeepin’,
Chris
