if you’re talking about the one at the t case,I heated it up and used a pipe on a floor jack.
It’s the one that’s mounted to the body I think near the muffler. And my exhaust isn’t anywhere close and I think it’s because of my body lift.
You gonna have to remake all of them,did you raise the engine and steering shaft?
I used it as an opportunity to pull all my exhaust up.
There are no OEM exhaust hangers mounted to the tub.I believe so! I don’t have issues with any of them except that middle one for some reason. And I just assumed it was because of my lift since that one is mounted to the body and the rest are mounted to the frame.
Starting at the exhaust manifold, there is one or two in the form of flange connections. After that, it goes around the front of the oil pan, shoots back to beside the trans and t-case and there is a hanger from the cat to an exhaust mount/"hanger" that is part of the transmission mount. Behind the muffler is one that goes over to the frame and then one beside the gas tank that hangs down off of the frame.Hmm weird what’s that one in the middle mounted to and do you know why my others would line up and not that one. I only have messed with cat back so just muffler and tail pipe
Help us out: How isn't it aligning? Which way does it have to go? How close does it come?
It looks like you have it pieced together. Have you loosened up all of the joints so it can flex a little?
