I will and yes they are time consuming. I just might bring s spare tranny as this will be new![]()
Hey Mike ,are you doing the vent mod,might have to cross a creek or two up in the Rocky’s.
I am excited to see what all it takes! Let me know if you could use some extra hands![]()
Thank god we have Blaine to rely on for accurate and detailed information.
I've seen your hands....not sure I want them touching my junk![]()
Correctly, if the TC has any sludge in it, that will settle and harden. It won't move easily and then can become a weight that throws off the balance.Ok, short information update that has been updated on the individual posts.
YOU DON'T KNOW WHAT YOU DON'T KNOW.
I'm in that boat and trying to learn. Thank god we have Blaine to rely on for accurate and detailed information. Consulting with him has prevented me from probably hours of wasted or ill directed time. My goal is to have this thread help others, so I will copy/paste pertinent information from other threads to try and have it all in one place. I did update some of the previous posts, but I will list newly learned information now for those that don't want to go back.
First, I bought this transmission from a salvage yard. Come to find out, it is rebuilt. The fluid looked very clean and I expect that it will run fine. However, understand that if a torque converter sits for a long period of time, sludge can build up on the bottom and throw off the balance. You can get vibes and not even know where there are coming from causing you to chase down driveshafts etc. A new torque converter is generally recommended. I am going to take my chances with this one since everything looked so clean. If I have issues with it, I'll replace it.
Transmission mounts are all the same from 97-06. What is not the same is how they get adapted between the transmission and belly skid. Up through 02 with a manual, the bolt right to the bottom of the trans and land on the skid plate formed crossmember. The auto has a roughly square adapter that bolts to the forward formed section on the belly skid and then the transmission mount bolts to that.Next, the transmission bracket is one piece, not two. the rubber transmission mount is the same across all years. You learn something new every day!
Anti-drain back valve is generally required so you don't have to wait for the torque converter to charge when you put it in gear.Next, when we did Josh's and Matt's 42RLE swaps, we had to add a bushing after removing the pilot bearing. The 32RH doesn't require that. It goes right into the end of the crank shaft.
Lastly, the stock cooler lines have a valve in them whereas the SS Tubes lines i bought don't have one.
I'm surprised that this isn't more common knowledge. Apparently you can get a shift kit and do some mods to the valve body that eliminate the need for the drain back valve.So these are the lines I got from SS Tubes. They don't connect like the factory fittings, but they do include different size fittings that fit the same holes. My concern is the missing check valve as these don't have one. I need to try and source new lines I think.
^^^ proxy quote via hosejockeyDon't run it like that for long as the CEL will stay on and it may need to be on for something else that is more important that you won't know about.
I'd do this before I tore into the valve body. Especially since it is a Mopar part, it is how they came from the factory, and it works. Doesn't hurt that this is probably the cheapest auto trans part we've ever seen, or very close to it.The other possible option from my research is a check valve that is added in line between the steel line and the hose. I just can't find any true OEM replacement lines. Everything is similar to what I already have.
I don't ignore things like that, ever. I don't ignore leaks, clunks, clicks, pops, MILs, and similar. Just can't do it.because none of us are alread conditioned to ignore the CEL....![]()
If I missed this, apologies. When we are routing the lines in and out of the radiator and through a cooler, we typically need to know which is the out and then the return. The 32 is one of easier to identify which is which. The out line is higher pressure so it has a flare fitting. The return has used up the pressure going through the cooler(s) so it is much lower pressure so they used the quick disconnect style fitting where you just squeeze the tabs and pull the line out. Works the same as the fuel line at the pump and several other places.Ok, short information update that has been updated on the individual posts.
https://www.ebay.com/itm/1470385427...pid=5337789113&customid=&toolid=10001&mkevt=1
That said, it is very common for the front port to let that hard line flare nut turn the fitting in the trans, twist the hard line and kink or ruin it. You are replacing it but others may not know what needs to be done.
If you use alignment bolts to mount the trans, pop that bracket off that is trapping the bellhousing bolt. I have long bolts that I've cut the heads off of and slotted the ends of. I screw those into the 3 and 9 o:clock holes in the back of the motor to aid in lining up the trans.
Not for nothing but using Oetiker clamps on SS braided hose is pretty retarded. Either use the screw on ends that convert them to something you can deal with or make your own. I specifically converted to the SS versions so I could cut their ends off and silver braze on -6 AN male. I can send you a couple of flareless bite fittings that will do it without brazing.Any reason to not use a double barbed style like this? The SS Tubes I have just use an oetiker clamp for the hose. This style would allow me to use a short rubber piece of hose between the tube and valve. I would need to put a heat shield around it to protect it from the exhaust.
