What are you doing for a cam?
Stock. If I spend any more money it'll be on a LS or 5.2 or 5.9.
Stroker kit made sense because it wasn't too much more than the needed parts. Biggest outlier is the stroker crank.
Meanwhile I've been working on cleaning up details on mods.
First off...made some progress on my iBooster. Had some CADssistance from an awesome forum member who whipped up a DXG file I could send to OshCut. Need a .70 end mill to counterbore the flange nuts into the plate and cut the iBooster studs flush with the plate. Then stainless studs into the adapter into the firewall. I'll post more on the iBooster thread once I get an end mill.
Reworked my power pods at the back of the Jeep. Eventually need a 3d printed plastic block but I just kept carving on my plywood and mode something perfect. Plywood originally pushed the ports under my Hooke Road rack...so a bevel to bring it further under and a notch to clear the Moryde tailgate reinforcement bracket...plus added a switch so I can reduce phantom loads while parked.
Installed some 8g cable and a 800w pure sine inverter. New laptop won't run on my 400. Eventually might run the 8g to a DC to DC converter an a lithium ion battery. Really need to rethink and rework my battery area. Need a more compact fuse block and relay assembly...all the small ones take expensive proprietary crimpers.
Replaced the oil temp sensor. I crushed it accidentally because I didn't realize it wouldn't fit in a T. Was leaking oil out the top but reading correctly. Also mounted the gauge. Eventually I want to 3d print a pod. Also want fuel pressure and temp down here.
Crank position sensor I ordered was wrong. Getting constant misfires. 300 and most of the rest of the cylinders. Figured I should try a sensor. Gonna swap it out and grab a compression tester tomorrow.
Also installed new wipers, cleaned up some brake fluid that leaked out of my spare can and vacuumed up a ton of pine needles and other debris that just collects in corners.
Amazing how the last ten percent of a project takes 90 percent of your time.
