My transmission connections look exactly like that as a bundle.
yeah, that was from your pic on page 1.![]()
Your donor Tran is of a different year range where the NSS and the TCC lock up were combined into a large apex connector.
Your harness is different but everything is there.
Shit, thinking about this, it's a remanned transmission, so who knows what year it came out of.
Good questions... the trans mount is 2 pieces. The rubber bit that bolts through the skid, and then the exhaust hangar plate thing that goes between the transmission mount and the case. There's a hole on the passenger side that the exhaust support bar slides through. No clue how that works on a manual.
You mean the transmission breather? You can either weld the pump vent closed or tap it and thread a plug in. Then drill & tap a hole on the top aft of where the kickdown band is, so like 2-3" behind the "shoulder" on top of the case. I'm 99% certain that every post about it puking fluid after the breather relo is because there was a low point in the new breather hose that allowed fluid to collect. Mine puked until I fixed that, hasn't happened in going on 4 years.
Yesterday was a little about some small stuff like hooking up wiring, vent line, O2 sensor, speedo wire. A lot of the day was spent on figuring out my crossmember. As you saw in the previous pictures, what I had wasn't going to work. So I cut the mounting plate off and started from scratch. With the CM needing to move forward just a little bit, I had to cut the mounting tabs off the frame and relocate them. It was a bunch of fit up, measuring, checking for clearance, tacking in place and re-checking everything. Rinse and repeat a few times to make sure it was as good as I could get it.
Things to look out for when doing this is the relationship of the DC joint for the front driveshaft. If you're not careful, the crossmember can interfere with it. I didn't have that issue, but I discovered that I'll need a new front driveshaft as mine is just a tad bit too long now. You also need to ensure your exhaust setup doesn't contact the transmission. I have to relocate the hanger mount is all which will be easy. Lastly, the transfer case moves forward about a 1/2" or so but the skid plate doesn't. Be sure the t-case doesn't contact anything on the skid. I have an old Rokmen skid that I cut everything out and then added a piece of angle iron as a stiffener. Everything still clears.
All I have left now is finishing the cooler lines, installing the TV cable, and hooking up the new temperature gauge. I THINK that's all I have left before moving onto the filling procedure. I'll double check everything before I move on.
That crossmember doesn’t (bolt to the transmission) does it?wont that break the housing?oh or you using this as a the transmission mount instead of the skid.
The crossmember bolts to the transmission mount. The isolators are at the frame. The skid is just a skid, not a mount.
Back in the saddle! Successful rocket surgery completed! Having never been on the inside of a transmission before, it's very intimidating to say the least. I'm usually one who when I do it the first time then I'm good after that. And that's no difference here. The valve body came out easily with the help of Craig to get me through things that weren't going the way I thought this should be going. I don't recommend learning the hard way, it's pretty stressful.
Now back to our regularly scheduled program....
