2005 Wrangler Unlimited Sport 6 Speed Manual with 160ish thousand miles. Had for almost 3 years and about 30k miles. PCM has been replaced with Wranglerfix PCM about 2ish years ago.
Since September, I have been fighting misfire codes, initially a p0301 though at some point of throwing parts at it, I got a few p0304 and p0300. Currently I am no longer getting a misfire code, the only code I am getting is p0172 (system too rich bank 1) but I am still getting a flashing CEL, usually at idle or in stop and go traffic. I believe a flashing CEL implies misfires but it is not storing a misfire code anymore.
I have done the wrong thing by throwing parts at it to see what sticks and am currently at a loss and looking for direction on what to try next.
Here are the things I have done:
- Spark plugs - first did Autolite iridium fine wire something or another gapped at .040. Reading about spark plugs makes me want to shoot myself in the face by the way. To make sure that those plugs weren't part of the issue, I have now gone to Champion copper basic plugs gapped at .035. Not honestly sure at this point what the original plugs were but they are all around .050 when I took them out.
- Fuel injectors - new 4 hole K Suspension injectors. The previous ones were unknown brand 4 hole injectors and the plastic nipples were cracked so while I don't think this caused or fixed the issues, I feel better with these being replaced.
- Ignition coil - first swapped with a used but known good coil, did not fix the issue. Ended up installing a new Delphi coil as the original one had some cracking in both the rubber and plastic
- Tested fuel pressure to make sure pump wasn't bad. I am forgetting the exact psi right now but it was in spec.
Thoughts on what I should look at next? O2 sensors or testing the existing ones somehow (pointed that direction from the p0172)? Investigate catalytic converter maybe? Dive further into OBDII live data? Take the head off (dreading that)?
Other things that may be useful:
- Crankshaft position sensor is OEM Mopar and was replaced within the last 3 years
- OPDA was replaced with updated Crown unit, OEM camshaft position sensor was reused. during troubleshooting this issue, we swapped to Crown camshaft position sensor but issue was still present so swapped back to OEM
- Swapped back to OEM PCM (as OEM PCM only had issues on hot summer days and its cold now). Issue still present so swapped back to Wranglerfix PCM. I have also reached out to Wranglerfix to see if they have any suggestions.
- In looking at all of this, we inspected the injector wiring and found some bad wiring on number 4 injector. Bought and installed a new pigtail, I think that was what caused the p0304 and have not seen p0304 since.
Scratching my head a lot and about to find a shop to take it to. Thanks for the help guys.
