Agreed, just throwing it in there.
I have done the wrong thing by throwing parts at it to see what sticks and am currently at a loss and looking for direction on what to try next.
Not purposely being disrespectful, AndyG, so don't take this the wrong way: I try not to "just throw things in there" when diagnosing problems, especially given the OP's post:
Even our beloved TJs have complicated engine control systems, so it pays to use an evidence-based approach. You are 100% correct that the vacuum elbows disintegrate and will cause rough running conditions, but I don't see that as solving a problem (running rich with new cats) that could be costly if not addressed.
Again, no offense meant - just explaining why I made my previous post reacting to yours.
Regulator is in the tank.Thanks for the suggestions on checking for vacuum leaks. We have inspected everything we could think of for vacuum leaks and also did a smoke test and could not find any leaks. Planning to work on it some more on Friday so I will take these suggestions and see what we find. The flashing CEL, when it does happen, is at low speed or idling, never when cruising, so I believe (or am hoping) that when there is a misfire and maybe rich fuel condition, it is a small percentage of time and hopefully not doing damage to cats. We shined light through the precats and they look to be in good shape currently.
My plan for Friday is to check fuel trims to see if that points us anywhere, remove and inspect CPS, and I would like to check the flywheel bolts. Maybe that is dumb and not something I should waste time on. Speaking of that though, is there an inspection cover on the NSG370 that is easy to remove to check flywheel bolts?
I'll also check the sensors that SAB mentioned. For fuel pressure regulator, do I have a separate one on my 05 or is it just in the pump assembly? My fuel rail has a little silver top hat looking thing and no test port. When we checked fuel pressure, I think we adapted something to connect to the soft line that goes into the fuel rail.
You also list ECT sensor, if that was bad, wouldn't I see some change on the temp gauge? It is always right in the middle (205 I think?).
You can use the fuel trims to see if your richness issue is only occurring only under certain conditions. The main axes in the pulse width table are throttle position (engine load) and rpm, so think in those terms (what is my throttle position, and what speed is the engine at) when you are seeing or not seeing fuel trims get pinned at a negative value (removing fuel because it's rich). More fuel is introduced under both high load and high speed, so if you're only seeing a rich condition (negative trims) at low loads (light throttle) and low speeds, you stand a much better chance at avoiding a cat failure prematurely....The flashing CEL, when it does happen, is at low speed or idling, never when cruising, so I believe (or am hoping) that when there is a misfire and maybe rich fuel condition, it is a small percentage of time and hopefully not doing damage to cats.
My plan for Friday is to check fuel trims to see if that points us anywhere...
There is no inspection port. Look at the pictures in Post #390 of my build thread, especially the second-to-last one. However, if by "flywheel bolts," you mean the screws that hold the flywheel to the crank, you won't be able to see those until you remove the clutch pressure plate assembly and the friction plate because they both cover the flywheel mounting screws. If you wanted to take a peak inside the bell housing on the transmission side of the clutch, you could remove the clutch slave cylinder and look in that hole (visible in the pics I linked in my build thread.) Also, when you remove the crank sensor to inspect for rust on the sensor targets, you might be able to spin the crank and see if there's visible axial runout on the flywheel, which could be attributed to loose screws (or a bent flywheel.)Speaking of that though, is there an inspection cover on the NSG370 that is easy to remove to check flywheel bolts?
The throttle position sensor (TPS) is on the throttle body, and it's on the list of possible causes I posted. There are two tests you can do to rule out the TPS when you're looking at live data on your scanner tomorrow:My friend reminded me that I have left a couple of possible variables out of this post but they are things that I think should be unrelated. I am running a Banks cold air intake, a Banks Monster cat back exhaust, and a Banks header. Also a 62mm Edge Trail Jammer throttle body. I am not using the piggy back ECU portion of the Trail Jammer. All of those things were installed and the Jeep running fine before this issue came up (for like a year). We're gonna look at fuel trims, map sensor, CPS contacts tomorrow and will report back.
verified the front cats are in good condition (Jeep has 160k miles, and someone replaced the front cats with MagnaFlow before I bought it at 130k miles), gutted the factory rear cat (which did not show light in about 50% of the holes when checked with a flashlight).
The rear cat doesn't have any 02 sensors at least on my 06.
I recently found out I had been using an illegal cat (California BS) when trying to smog my Jeep, so I had to change it, and I'm glad I did because my Jeep runs a whole lot better.
My jeep was driving just fine before. I didn't notice any signs of performance loss. It was louder though. When I removed the cat everything inside was still intact
I do not believe they are causing any of my misfire issues.
Not sure the 4.0L has the option
I would expect the TPS to either be working or not, but intermittent problems are always possible. Looking at it with the engine off (key on, of course) and then when your CEL is flashing would rule out the intermittency.Assuming it passes this test without the engine running but I am able to reproduce the flashing CEL later on, would you recommend performing the test again with the engine running while the CEL is flashing? Or maybe turn off the engine and run the test again?
I don't believe the NGC PCM has a misfire counter, either. But I'm not 100% sure.My 97 has no PID for misfire count and both my Innova 5610 and Torque/Bluetooth dongle can't find it.
When you're working through diagnostics, attention to detail is very important, especially if, because you don't know exactly how the logic in the PCM works, you have to follow the test procedures. Both TPSs are fine. Look back at the test procedure with more attention to detail:Edge Trail Jammer 62mm throttle body...TPS voltage with engine off measured .77, not .92. We swapped to the other TPS sensor and it tested at .72 volts. Both sensors seem to work fine and register between approximately 15 and 80 percent when using the throttle.
If I’m understanding correctly, I believe the NGC has a misfire counter since I can observe real-time misfires. My gauge only tracks cylinders 1-4 since the Neon SRT4 folks asked for this function.
