I know some people struggle but for me it wasn't. Another side affect of my adhd, never have felt addicted to any drug or alcohol. Never felt like I needed or couldn't wait for another whatever.
I'm 2-1/2 years without a drink now.
Like you, I didn't have any struggle putting it down, my health was too important to even consider another.
Friends ask if I notice a difference now that I'm not drinking.
I usually tell them that I'm not a drunk asshole anymore, now I'm just an asshole. ;)
Had nice weather last night so I decided to fix my leaking shaft seal on my Dana 35. Most of the repair time was spent finding a 1/4” 12 point socket. Knowing what I know now I will absolutely be changing diff fluids as soon as I buy another TJ… it was disgusting!!
Did you inspect the axle surface and roller bearings for abnormal wear ?
Your rear bump stop also appears to have rotted away.
I did. The shaft didn’t have any change in diameter / edges. Bearing inside looked good too, surprisingly for how bad the oil looked. I plan on doing the next diff oil change at an earlier interval.
I was waiting for someone to notice that. That rear bump stop got obliterated when my suspension bottomed out at silver lake sand dunes in Michigan when I was coming down the back side of “test hill” 😂. PO put in a rough country lift, way too squishy and they didn’t set the bump stop height right. Hence the reason the track bar relocation mount put a nice dent in my floor.
I'm going to check everything out today after work. I had a parasitic draw a couple of years ago, then noticed my driving lights came on randomly when the Jeep was parked. I replaced the multifunction switch, but it can't hurt to check the connector too. I have a spare MFS if I need it.
UPDATE;
I bought a headlight wiring harness ( K-Suspension) and did a test fit in 5 minutes. Headlight works now. I will install it properly when I have 20 minutes to spare. Hopefully it will keep the headlight working for good. I'm still skeptical. 🤔
UPDATE;
You will find (if they haven't redesigned the harness) that the relays and wiring are counter intuitive to the way the harness should be designed.
IF the relays go bad; good luck locating replacement relays.
The better option would have been to use the harness included with the Toyota H4 headlight package.
If it works for a year, I'm good. It was really cheap (like me) on eBay. Not a fan of the Toyota lights themselves.
I have put this on two of mine. Such a good upgrade for brighter bulbs while keeping them halogen and a stock look. Really hard to beat when you can get the kits for $20 or less from the dealer
Halogen and bright should never be used in the same sentence IMO. Probably why NO new vehicles have them.
p.s. That's like saying, "I have a new TJ." ;) 🥳
I like how my new glass headlights don't have that clear crystal cheap look that many of them have.
I thought the same with the stock bulbs, I believe I run 80/100’s now. Maybe I have a little bias with all the extra fog/flood lights I added haha
(y) This is my cheap Chinese driving lights with my headlights off.:cool: I drove 3 miles the other morning and didn't realize I had my headlights were off until I got to my destination.
I can remember when Halogens first came out - DAMN they were BRIGHT compared to the standard incandescent headlites that preceded them.
Listen to Brian Lohnes' podcast Dork o Motive where he talks about the brief history of acetylene headlights on cars...they kept blowing up neighborhoods manufacturing and bottling this stuff.
