Under hood light fuse location?
MexiJeeper
My under hood light quit on me. Nowhere is that fuse identified. Anyone know which fuse # I should be looking for and where? Thanks all.
The factory service manual for my 2006 shows the Underhood lamp is fed from Fuse 26, 10A, in the power distribution center
Screen shot of the page in the manual where I located the info.
Reactions: MexiJeeper
Jgaz an awesome thank you to you sir. That did the trick and yes it was blown.
I just installed these LED module lights and must have shorted the wires. I'll do a night time shot later.
Anyone know if you can buy the plastic connector housing if for the harness? Lol.
From 15 years of engine heat mine assploded as I pushed the red connector lock back.
As far as the light it was a corroded mess, time to buy a whole new fixture
Nice...how did you control the on off function through the factory light?
The white wire is to the LEDs. Fed it through the back of the original light. I also broke off the locking tabs of the connector so that I could pull off the plug easily to turn off the lights when not needed.
