Hey guys,
Currently in the last steps to finishing my TJ build and ran into this issue.
As you can see I’ve stretched my jeep quite a bit and I’m using the genright alien crawler fuel tank. The problem is that the fill ports on the gas tank are yes practically the exact same position as stock, however I’m not able to put the filler neck in the stock position. If i go where the license plate use to be the outlet of the filler neck is too long and i would have to do some crazy bends to bring it back. Not to mention the potential of my tires hitting it when flexed out. One thought came to mind is putting my tail light on some kind of hinged door where i open it and the filler neck would be behind it. I dont really want to put it inside the tub since i do run a softtop in the winter and would be a pain getting to every time i fill up. Not to mention the potential of gas spilling into my cab would be less ideal also.
I guess my question is, is the tail light door something i can find aftermarket? Or is there some other option i should do that I’m not seeing?
