New TJ Hood
Reminds me of the old AEV hoods. Those I liked. I don't trust the Chinese fiberglass knockoffs or I would run one of those in a heartbeat.
Edit, I actually just did a quick search as I haven't looked in a while, but it looks like there is a CF version available now, but I know nothing about it:
https://www.mobbmotorsports.com/199...2hT26bcrdK294-p5DyK8xpWiZhtNtn-RoCBO8QAvD_BwE
But for the price, I am interested, I would have to paint it, I would never want it to look CF
That hood is from Carbon Creations which also has duraflex highline hood
https://carboncreations.com/select-vehicle/jeep/wrangler/2005
For the cost, I'd rather not run steel since it's heavier and can rust. Similar to why steel corner armor isn't desired by those who don't like rust or making their rig heavy. It all adds up.
I guess I'd have to see a quality hood before I'd spend the money... But my Jeep is a pig too...
Reactions: John Cooper
I'm probably over-thinking a bit, but I have a question for the drivers of Jeeps with louvers...at low to moderate speeds, is there ever a time when the heat leaving the hood is felt in the cabin area? (With the doors/top opened up)
I know before I added some insulation under my console around the shifter, I felt I could fry an egg on the shifter boot, and that heat radiated into the cabin.
I never noticed a difference and I wear shorts most of the time.
You saw one up close in Sand Hollow. ;)
I didn't look that close.
Ribbing aside, you could always ask folks on FB for their opinions of an aftermarket hood they have or for fitment photos before making a purchase.
All the guys I've seen commenting who purchased a fiberglass or carbonfiber hood have been less than impressed with more than a few who had to spend $$$ to make it right in either fit or finish or both... Which is another reason why I'll stick with steel....
Reactions: mudmaster and Zorba
This is the main reason I want either louvers or a heat reduction hood. I get hot ass air blowing on my legs, it's not from a torn shifter boot, but fixing that did help.
This thread started me down a rabbit hole today (sorry to my employer) that I had thought I had come to a final decision on, but now the gears are turning again. Wildman, I think you have been over this topic many times over the years too, looking back at some older threads, I am glad to see I am not the only one who can't seem to find a solution that checks all the boxes.
Originally when AEV made hoods, that was my plan, then they stopped. Now I am trying to lose weight anywhere it is reasonable. I need a new hood already, so why not try to find something that is also lightweight and a little more hail resistant. When I first looked for CF options, there weren't any. I was thinking of getting a stock (no hilines for me) fiberglass hood and adding a Genright louver. At least that would cover the big flat section where most of the imperfections in the fiberglass would be noticeable. I would have to be careful where I cut and maybe add something under the hood to reinforce where the hardware is used and distribute the stress on the fiberglass. But then I am buying a brand new hood just to cut it up and create another project.
Now there is the CF option I linked before. It is hand laid, so basically the lowest quality of CF available, which is reflected in the price. The quality should be much better than fiberglass but I am still not sure it will be good enough. And I would prefer at least some CF over pure Fiberglass just for some strength.
Also, I think I have grown to like the look of the louver more than the AEV hood. At least I think it matches the rest of my jeep better.
So now I know nothing.
Not in any way I ever noticed
Reactions: 06GEEP
You wouldn't have known if you did.
My understanding is that's been a problem with aftermarket hoods in general.
Good thing they put RockMonsterUSA as the website name so you'd trust their steel offerings.
https://www.aliexpress.us/item/3256...0SCz7wfUPvxoCZSkQAvD_BwE&gatewayAdapt=glo2usa
https://www.aliexpress.us/item/3256812544875536.html?spm=a2g0o.productlist.main.3.57d87bd02Ha6g9&algo_pvid=d47569e3-dc9f-4051-95a2-6528d6b1e3c3&algo_exp_id=d47569e3-dc9f-4051-95a2-6528d6b1e3c3-2&pdp_ext_f={"order":"-1","eval":"1","fromPage":"search"}&pdp_npi=6@dis!USD!862.67!767.78!!!5758.79!5125.32!@2101e81117895204355523270e1022!12000059157381007!sea!US!0!ABX!1!0!n_tag:-29910;d:be3edc2f;m03_new_user:-29895&curPageLogUid=g0X8C4cb8qS9&utparam-url=scene:search|query_from:|x_object_id:1005012731190288|_p_origin_prod:
Edit: Interestingly, the second link only works for me if I copy and paste it. (free shipping)
Reactions: jjvw
I'll stick with my "custom" hood tyvm
  • USA Proud
Reactions: MikeE024
I know a little about that style of hood and remember when they were first offered too..
Sadly it does seem to be the case.
I never implied or assumed that it was made in the USA...
Surprised someone hasn't done an aluminum hood.
I believe JLs have come that way from the factory since 2018, and Gladiators have come that way since 2020.
I haven't looked into aftermarket offerings.
Edit: apparently there is a steel hood as well for 2026 due to aluminum shortage/price increases.
Reactions: macleanflood
