Need recommendations for a new set of calipers. As a millennial, I prefer digital, but I can read analog
. I’m not doing high precision machining, but need more accuracy than my $5 eBay ones
Need recommendations for a new set of calipers. As a millennial, I prefer digital, but I can read analog. I’m not doing high precision machining, but need more accuracy than my $5 eBay ones
If you can afford Mitutoyo solar powered digi-calipers, by all means get them! I had a set at work that mysteriously disappeared. I think Santa needs to bring me a new set for my very own...
Personally, I'd go with dial calipers long before I'd ever used another Vernier caliper. I know how to read a Vernier, but it's not nearly as quick to read as a dial or digital, and when I'm designing something and making 4 or 5 measurements in rapid succession, I feel slowed down by the process of reading a Vernier scale.I’ve got the perfect recommendation for you:
https://www.amazon.com/dp/B0B4Y1MKJT?tag=wranglerorg-20
I’m so glad I asked for one for Christmas. I didn’t have high expectations because of the low price but they are great! Really smooth, nice finish, and well marked. There’s a few different variants of length and decimal/fractional marking, so pick your preference.
If time is money, and it is, I can justify a better option in less than one design exercise...
On a serious note, someone gave me a plastic digital caliper years ago. I used it once and tossed it. I could vary the measurement by ten-thou easily just by varying my thumb pressure on the thumb wheel. Caveat emptor!
No, I don't use my dials much. When I'm designing something, I'll often be making something like five measurements in as quick a time as you can physically do it while marking down the numbers, thinking of my design while doing it. A Vernier is a horrible option for that because I have to pause with each measurement and think to interpret the reading, and that disrupts my design thought process. A dial is way better, but even it requires a short thought to interpret the dial reading and add it to the scale reading to get a complete number. With a digital caliper, I simply read the number, write it down, and I'm off to my next measurement without losing my design train of thought.@sab, do you still use your dial calipers, or mostly digital? What is the big advantage in digital calipers?
In that case - Dial, baby, dial!I actually do have an electric one, but like you said the batteries are always dead when I take it out of the box. Hence my superior suggestion!
I own close to two-dozen calipers and micrometers, from Vernier to dial to digital. As for digital calipers, I have several cheap brands and several Mitutoyos. What I've found is that all the cheap brands utilize a "wake-on-movement" option so that as soon as you move the thumbwheel, it wakes up. On the other hand, the Mitutoyos all have to be turned on with the power button. The convenience of the "wake-on-movement" function is nice, but there's a massive penalty for that convenience - poor battery life.
The Mitutoyos draw almost no power when they're off because all they need to do is keep the zero point in memory. On the other hand, the cheaper ones will draw the battery down in a matter of a few weeks even if you never use them because it takes a lot more power to monitor for activity than it does to maintain the zero.
Good point, although I rarely do anything in metric, even for 3D printing. My brain is programmed for thou, not mm.The ability to measure in any units without need for conversion comes to mind. When working on something where the end result will be 3D printed, I often work in metric, but depends. It's nice to be able to change up your units on the fly.
The biggest advantage is instant switch between mm and inch.What is the big advantage in digital calipers?
