Operation Phoenix
Ok...covered some of this on What did you do page...
Driving downtown Eugene headed home from a dental appointment I heard a large pow like the transmission jumping out of gear. Steering felt funny. Noises from what sounded like the front end. Looked that over. Rear wheels definitely locked...chirping going over corners.
Drove it 20 miles home. Drained the rear diff. First indication of a problem...
Popped the cover...
Appears that 767 miles after my outter pinion replacement the snap ring holding the retention pin fell out. Assuming that's on me for not seating it properly.
Elocker is toast. Pin got into the spiders.
Plan: ordered $2100 worth of parts. This will be my third rear E-locker. First one was set up by a shop in Roseburg and died a thousand miles in when the rear end grenaded on my way to Montana. Had my father in law take it to my favorite transmission shop and worst idea ever...have them replace the R & P while they fixed the transmission for the eighth time. They claimed the pin was stuck in the E-locker and cut it out with a torch. They sold me a new one. Their regear didn't last long...they didn't loctite or properly torque the ring bolts...so that's what I found 767 miles ago. I more or less ignored that issue for 5000 or so miles.
So...plan...new locker...5.13s. New carrier bearings. Front high pinion Dana 30. Got ball joints ordered for the housing. Inner seals. Got a new Delphi connector ordered for the front locker...it got crushed a while back.
Question: what should I do to reinforce the passenger axle control arm tower?
Question: convert to a JJ for the axle side or keep using factory bushings.
Question: suggestions for a good Delphi/Metripac crimper that doesn't cost a fortune ?
Question: how do I secure this fucking snap ring?
Question: what am I missing?
Sucks that I'm in well north of $6 grand on this Dana 35.
I don't think such a thing exists. With those terminals, having the right tools is critical, but they're probably not what you're looking for because they cost real money. I get my Packard/Delphi/Aptiv (they were Packard when I bought my first ones) tools from:
https://crimpsupply.com/tools/packard-tools
Popped the cover...
View attachment 711701View attachment 711702
Damn Mac....
Can I ask WHY???
If you're rebuilding that would the difference be in cost to swap to a Dana 44??? They seem to have come down in price some over the past few years.
Damn Mac....
Can I ask WHY???
Already own 30 spline shafts. I don't have a 44 housing. I don't want to spend the time finding one. I don't want to have to purchase another driveshaft and a shorter one at that. I don't want to cut off shock brackets and weld new ones on to support my outboard. I don't want to have to buy another armored rear cover. I don't want to have to put on another track bar relocation bracket. I don't want to mess with a different emergency brake cable.
How's that for a start? =)
So basically bodge my way through with pliers and maybe a dab of soldier. Grr but not my first rodeo.
Pliers?
Reactions: macleanflood
That wouldn't be the way I'd go, but you have an unusually high tolerance for your rig letting you down. I'm the opposite.
Which of those many crimpers would work? I don't mind investing. It's picking the right one.
Popped the cover...
You bois mock me, but Tonz and Fodeez don't sound so 'spensive now, eh Mac?
Nope. Exactly my point!
Depends where you want end up. I want stock width axles and 35s, hence my built HP30 and 44. A super 35 is OK and didn’t fail me like you have experienced. I admire your perseverance but at this I think you should reflect on where you’d like to be with the rig in 2-5 years. In some other rig: fix the Dana 35. Doing bigger stuff with this rig: Dana 44 or get some JKR axles. TJ6: tons and 40s.
Reactions: bbaldwin237
I think I'm happy with the axles. The failures were not the locker...just botched installations. I let others do the work and I paid the cost. My mistake. Moving on.
I want to replace the front shocks with Fox 2.0s 11 inches and a poly performance tower. That might involve new fenders and a highline.
I want an Atlas transfer case.
I want to lift the rear bumper and get a better gas skid.
I want more aluminum.
Then I'm happy to just wheel this Jeep. Lots of interesting places to go.
I know this story. It is expensive to learn what you need and that its better if you learn to do it yourself.
