I'm a new member here on the forum. I've had a 2000 Jeep TJ for a little over a year and installed a few upgrades. I have some questions concerning the Dana 35 differential expected performance after upgrading. I understand the desired upgrade would be to install a Dana 44 or Ford 8.8 but need to really understand why. The Dana 44 with the 30 spine axle is only ~ 11% larger than the 27 spine Dana 35. The Dana 35 Alloy 27 spine alloy axles data claim they are 30% stronger than stock axles which I can assume the Dana 35 axles with 30 spine would be ~ 41% stronger than the standard 27 spine Dana 35 axles based on it's increased diameter. Would it be correct to assume both the 27 spine Dana 35 alloy and 30 spine alloy would be stronger than the standard Dana 44 steel axles?
