Note: I pulled the pics posted here from his Instagram and no, I will not release his insta. Been following this build for about a year now and now its for sale down in Alabama.
Straight from his Craigslist post:
https://mobile.craigslist.org/cto/d/2004-jeep-wrangler-unlimited/6652331517.html
2004 Jeep Wrangler Unlimited
78k miles on cluster
80k miles on engine swap
**Note: This is NOT a Rubicon!!! They didn't make a TJ Unlimited Rubicon model in 2004. Sticker is for looks, but build WAY surpasses Rubicon status.
Engine:
-2007 LS2 Corvette engine ~80k miles
-Sanderson 1 5/8" Block Hugger Headers
-Wide Open Designs Alternator/Power Steering Pump Relocation Brackets
-180 amp truck Alternator
-PSC power steering pump
-LS Truck Crank Pulley
-Dirty Dingo Sanden SD7 A/C compressor relocation bracket with Sanden SD7 A/C compressor
-HotwireAuto Custom Witing Harness
-Redline Gauge Works reworked factory cluster to work with LS swap engine.
Transmission:
-Brand new 4L80e Monster Transmission
-1800 stall converter
-Advance Adapters 4L80e to Atlas Transfer Case adapter
-Advance Adapter 4 Speed Transfer Case 10:1
-Adams Driveshafts 1350 front and rear custom driveshafts with 1300 yoke flanges
-TCI 4L80e stand-alone transmission controller
-Advance Adapter twin stick shifter with Planetary Shifter
Axles:
(Front)
-Currie Rock Jock 44 w/ 3.5" axle tubes
-Reid Racing Knuckles
-Timkym unit bearings
-RCV Axle Shafts
-Auburn Etec Locker
-4.88 Gears
-Artec Truss
-Wilwood 13" Disc Brakes w/ 4 Piston Aluminum Calipers
(Rear)
-Currie Rock Jock 60
-G2 Chromoly Shafts
-Eaton E-Locker
-4.88 Gears
-Currie RJ60 Truss
-Genright RJ60 upper Truss mounts
Suspension:
(Front)
-Custom 3 link mid arm suspension
-Genright Outside Frame Track Bar Mount
-Genright Trac Bar Kit
-1 1/4" MetalCloak Duroflex Joints
-2" Solid 7075 Aluminum Links from Wide Open Designs
-3.5" Rock Krawler Triple Rate Springs
-Fox 2.0 Shock w/ Adjustable Reservoir
-Currie Anti-Rock Sway Bar
(Rear)
-Custom Single Triangulated 4 link Suspension
-Rear shocks Outboarded and ready to acccomodate a 4" stretch if wanted
Steering:
-PSC gearbox w/ Hydro Assist Ports
-PSC Hydro Assist Ram
-PSC Flat Pitman Arm
-2.5 Ton Rare Parts Tie Rod Ends
-1 3/4" Solid 7075 Aluminum Tie Rod and Drag Link from Wide Open Designs
Misc:
-Rusty's Offroad Front Bumper
-Gatsby Trucks Winch Plate
-Warn Zeon Platnium 12-S Winch w/ Remote
-Rock Hard Rock Sliders
-JCR Offroad Rear Bumper w/ Adventure Tire Carrier
-Rotopax
-Hi-Lift Jack
-Corbeau LG1 Leather Front Seats w/ Seat Heaters
-Stock Interiors Complete Carpet Kit w/ extra heavy rubberized mass backing
-WeatherTech Mats
-SPOD switch Panel
-Bestop Rampage Soft Top
-Factory OEM Hardtop
-Factory 1/2 Hard Doors
-Bully 1/2 door Fiberglass uppers w/ sliders
-OEM Rubicon Flares
-Genright Aluminum Belly Up Skid Pan
-Genright Aluminum 23 gallon Crawler Tank
-Savvy Rear Billet Taillights
-Night Sun LED Headlights
-35" Goodyear Kevlar MTRs -Approx 500 Miles on them.
Needs:
A/C lines made and charging
No expenses spared in the building of this Jeep. Feel free to email me with any questions.
Asking $41k. I have well over that in this build.
Engine:
Transmission:
Axles:
(Front)
-RCV Axle Shafts
-Auburn Etec Locker
-4.88 Gears
-Artec Truss
(Rear)
-G2 Chromoly Shafts
-Eaton E-Locker
-4.88 Gears
-Currie RJ60 Truss
Suspension:
(Front)
(Rear)
Steering:
Misc:
-Rotopax
-Hi-Lift Jack
-WeatherTech Mats
-SPOD switch Panel
-OEM Rubicon Flares
Needs:
