4WD shift linkage rattle?
Nicholas
Tampa, FL, United States
So about a year ago when I got my Jeep it there was a rattle at acceleration and I coulda sworn it was the TC chain or the trans mount so got it inspected they told me it was the mount. Got that replaced went away for a week and then came back. Now I find myself having to hold the shifter in the downright position when accelerating for it to stop? Any ideas on how to fix this? It’s pretty annoying.
I tried un bolting the console piece and I still couldn’t get to it, gonna look at some videos later
You need to adjust it from under the Jeep. There are yt vids on it. Takes all of 5 mins. There are nylon bushings on the ends of the rods that can break, thus the inspection recommendation.
Reactions: Nicholas
X2 to other comments but also check the housing right where it comes through the floor. There is a wide linkage 2 inches maybe that is housed, that connects to your shift linkage. That linkage will vibrate back and forth( side to side) causing your noise that your referring to. I installed a few bid O rings to both sides. I no longer have the vibrating noise that your referring to.
