read the tons of info on this common issue and my question is this. my 2004 TJ holds 19 gallons, how much of that is actually available to the engine? I thought I read somewhere that about 5 gallons is not available and just sits there.
I'm trying to determine how many miles I can run before I need to fill it up since the fuel gauge is goofy.
it will work until I get about half a tank and then the needle goes to E and low fuel light comes on.
The gauge works fine according to the self test.
once I figure my MPG, I can then determine about how far I can go before I need to fill up but if I only have 14 gallons of gas available (assuming 5 gallons is not available to the pick up unit), then that will help me determine when to fill up.
thanks
thanks
