I see every variation of suspension and drive quality problems on the forum it seems .
Having owned 7 Jeep's , four wheel drive trucks , and so forth , and paid the bills to keep them rolling , here is what I have learned in 3 decades about drive quality .
Also , my Jeep TJ drives incredible . Smooth at all speeds , and that is no accident .
Here is why Jeeps, and all other vehicles, can drive poorly.
1. Wear . This category is a mix of all or some of everything .. gear box wear , bushings, ball joints , tie rod ends , steering column , knuckles , body bushings , drive line , etc. The hard part of roping this in is it's all in varying degrees based on what was maintained and what was neglected. This can be at any mileage point nearly , but becomes more certain as mileage increases if the vehicle was not maintained.
2 Time, Previous owner ignorance or neglect : I purchased an 03 Rubicon with 20,500 miles thinking it was good to go...it was , to the shop ....and it needed control arm bushings , shocks , tires , alignment , u joints and love . Sitting will ruin a vehicle , and off road , mud , water and pressure washers will age one prematurely. The wrong type grease can attack some bushings as well. Low mileage is not a panacea for all Ills, trust me ...and it's hard to swallow the added cost once you have paid top dollar for the vehicle .
3. Tires . Mud tires usually don't ride and drive as well as most All Terrain tires , and all Terrain Tires usually don't ride and drive as well as street tires.
Large tires generally don't drive as well as smaller . Generally .
New tires drive better than older ones usually , especially if they are near the end of their service life.
Name brand tires most often drive better than off brand tires .
Tires often aren't balanced as well as they can be.
Tire pressure is wrong, or uneven .
4.It's been butchered . Someone lifted it and didn't do a complete job , or didn't know what they were doing . This is all too common , and can be combined with all of the above .
5. It's not aligned properly . Yes , this happens even at professional shops , and even if it is perfect , it will eventually change .
6.Driveline issues ..worn knuckles ,u-joints , un balanced drive shaft , etc , contribute to a shaky, sketchy overall feel.
7. Comparison . If you drive a Lexus all day , your Jeep will be noticeably different .
8. Bad Roads . Roads that are awful beat you and your vehicle to death . New pavement is heavenly.
9 . Cheap parts. Avoid most house brands .
Here is my set up and why :
I started with a low mileage chassis hoping to at least have a good foundation to build on, and figured you pay either way you go , and I wanted a Jeep to enjoy a long time then possibly give my son.
I chose BF Goodrich 33" KO 2 tires for the look and quietness.
I chose Bilstein shocks because of their reputation .
I installed a rough country long arm kit because of the bushings being the same OEM part number as a 1-ton Dodge , and I knew bushing quality is important on a short , lifted vehicle . It needs stability. Also my shop was very familiar with their kits . I likely went that direction a the short arm kit it had was awful, so I went as far from that as I could. Both a one hump and a two hump camel will get you there .
I installed Spicer triple sealed u joints and a new double cardan . Mud and water had taken a toll on mine.
I keep it completely aligned and drive it sensibly , and grease it.
Don't buy into the "Jeep's drive bad" story ..anything drives bad that is set up wrong, has bad tires and has been neglected or abused .
I know I'm not telling anyone anything they don't know , but my point is this .... quit chasing the mythical magic set up and look at the practical aspects of vehicle ownership ... especially in a category where the vehicle is short , light , lifted , often has a history of off road use and needed better than regular maintenance . Any vehicle as narrow and short as a Jeep is going to react more dramatically to bad suspension and front end components and issues than a lower, wider , heavier vehicle . In short , good or bad , they handle quicker.
Thanks for reading , hope it makes sense.
