Death wobble after replacing wheel bearings
Robert Gessler
Kansas
Hey all, so I just replaced some bad wheel bearings (DIY) installation went smoothly and the noise is gone but now I've been getting the death wobble at about 60-65 mph usually when slowing down
I did not have this before I did the bearings. The bearings i bought were MOOG assemblies so not some cheap crap i found online or anything. I did a dry steering test and I didnt see anything obvous. Any help would be appreciated
Edit: checked my track bar and there is no play in it at all so its rock solid.
P.s Chris I read your post regarding wobbles and vibes.
Kinda feels like a demon is possessing the vehicle yeah its death wobble. (I've been in other jeeps with DW) only way to make it stop is basicly slowing to a crawl or stop
Yep, it is death wobble then in that case, as death wobble doesn't go away at certain speeds, nor can you power through it with more throttle.
Usually when it's true death wobble, it typically ends up being a bolt that isn't torqued down properly, and that usually ends up being the track bar bolts. Does it have anything to do with when you apply the brakes to slow down?
No it happens when I coast or use the brakes or even the engine to slow the vehicle. Or even if I just hang around 60 too long. I can cruise at 70-75 just fine though. sometimes it dosnt start at all.
I can twist my tie rod though so it has some play on it. It does take a fair amount of effort though.
